Hello Guest it is December 26, 2024, 08:57:18 PM
Author Topic: External Button for Auto Tool Zero  (Read 25331 times)
Re: External Button for Auto Tool Zero
« Reply #30 on: September 20, 2010, 11:00:33 AM »
Johnv, here are my files. I have to tell you that this worked great for awhile, then Mach would start to run the ATZ feature on it's own. I did have an issue with my computer and I have replaced it, but I haven't tried using this macro since then. Please let me know if you run into the same problem.
Offline johnv
  •  43 43
« Reply #31 on: September 20, 2010, 03:09:58 PM »
Hi ranchak & Greg,
The bottom line is, I got it running using ranchak's files, even though they are identical to greg's. I had another brn file running which I don't use, so I disabled it and I think thats when the ATZ started to work.  I went back to greg's files and they work as well. Greg & ranchak..... thanks loads!! :)
Johnv
