Thank you. I'll see how that compares w/ mine.
Just for my information, when you set a maximum feed rate in Mach 3 at say 60 in the motor configuration page, that sets the upper limit on what a G-code Feedrate command can be, right? I noticed that my toolpath ran correctly when I had errantly told BobCad that I was milling soft steel. The feedrate was set to approximately 4. When I corrected my error and indicated that I was milling aluminum, the feedrate was set to approximately 20. The same toolpath that ran correctly slowly caused the fault running at the faster rates.
