Hello Guest it is December 26, 2024, 07:53:10 PM
Author Topic: Parallel Port Test Pulsing too fast  (Read 10072 times)
Re: Parallel Port Test Pulsing too fast
« Reply #10 on: June 11, 2010, 10:08:30 AM »
yes it does require external 5VDC, it also has an ENABLE line that requires 5V and a safety charge pump....I am checking these now.
« Reply #11 on: June 11, 2010, 10:31:50 AM »
Turned out to be the safety charge pump. I had it enabled previously (jumper on breakout board set to enable)
It was not enabled in the output section of Ports and Pins. Regardless of the setting in Ports and Pins if the jumper was in the enable position on the board it disabled all motor outputs.
Thank you again for your time and assistance!
Kevin
« Reply #12 on: June 11, 2010, 11:16:14 AM »
