Hello Guest it is September 13, 2026, 10:08:24 AM
Author Topic: shark cnc-mach3  (Read 89339 times)
shark cnc-mach3
« on: June 18, 2010, 07:47:12 PM »
Gooday.
Trying to get mach3 to work with shark cnc.
I already have built a hobby cnc parallel machine that is working nicely.
I understand parallel port patching.
I am using a separate xp computer just for the nc pod/shark setup.
I have loaded ncpod driver and plugin formach 3.
They talk sort of.
It looks like x is y, y is x and z down is z up.  Im told 1600 steps per rev accel of 15. Any other setup details?
I cant seem to find a simple patch panel to swap step and direction that works with the pod.
I dont have a detailed table of step and direction and other patches for the ncpod/shark.
Does anyone have a set of screen dumps of setting up mach3 shark combo?
Any good threads on this?
Thanks Peter
Re: shark cnc-mach3
« Reply #1 on: June 21, 2010, 01:56:00 AM »
loaded ncpod driver latest from oemtech
loads ok and talks to shark cnc from mach3
loaded update nc pod firmware (2031)
ran updater.
Error code ncPOD not found.
How do I update the firmware?
Thanks Peter.
Re: shark cnc-mach3
« Reply #2 on: June 29, 2010, 01:14:02 AM »
I have a cnc shark which uses a NC pod.
I want to use it with mach3 and also basic control panel.
I run two different classes that use different software.
I see there is a usb driver for mach 3 called ncpod usb driver
I see there is a firmware installer (v2031) for mach 3.
Is it a matter of changing drivers to suit mach3 and basic control panel?
Or are there two firmware installers that are mutually exclusive?
Can I swap between firmware versions easily? If so how?
If I have two different pcs one with mach3 and drivers and the other with basic control ad drivers will that work?
Thanks Peter.
Offline Greolt
  •  956 956
Re: shark cnc-mach3
« Reply #3 on: June 29, 2010, 04:32:48 AM »
Peter
It seems that there is two different ncPod firmwares.  The firmware that comes loaded with the CNCshark and the v2031 (Mach version) from the OEMtech site.
The v2031 has a dedicated firmware loader.  I am not sure how you would restore the CNCshark firmware as I see no loader for it.
I emailed OEMtech with this question a couple of weeks ago,
There is a firmware installer for the Mach compatible firmware.
Is there a similar installer to reapply the "NCpod Basic Control Panel" firmware?
I received no reply.
Greg
« Last Edit: June 29, 2010, 04:35:17 AM by Greolt »
Re: shark cnc-mach3
« Reply #4 on: August 23, 2010, 08:24:14 PM »
I have just installed the "new" Shark control panel with the touch probe. Works in the Shark control panel. I cannot talk to Mach3 with the Shark driver in place. Will try to reinstall Mach3 drivers and see if that let's me talk to the Shark. I had the Shark working with the shark drivers up till the new control panel install and allowing it to install usb drivers.
will post more later
Doc
Re: shark cnc-mach3
« Reply #5 on: August 29, 2010, 09:57:53 PM »
With the Shark Pro updated firmware to version 61 and the updated shark control panel to version 10 (last digits of the revision numbers) Mach 3 no longer communicates with the Shark/NcPod controller.
hope someone writes a updated mach3 driver otherwise mach3 is useless.
Doc
Offline Greolt
  •  956 956
Re: shark cnc-mach3
« Reply #6 on: August 29, 2010, 10:19:33 PM »
As far as I understand it is either one or the other.
Mach3 or the Shark Control panel.  They use different NCpod firmware.
For me it would be a no brainer.
I could not imagine trying to run a CNC router with a control as limited as the Shark one.
But then I am familiar with Mach.  Been using it for some years.  You may have a different viewpoint.  :)
Greg
