Hello Guest it is December 22, 2024, 01:14:45 AM
Author Topic: Hurco mill want to run vipers with Mach 3  (Read 3732 times)
Offline Jackal
  •  171 171
« on: June 26, 2010, 08:40:25 PM »
I've got a Hurco mill that has servo motors on it and I want to run Viper drives and Mach 3. The hurco replacement parts would pay for a retrofit in no time.
How hard is it to tune the Viper drives?
Any advice appreciated.
JAckal
Everything is bio-degradable if you run over it enough with a lawnmower.
Re: Hurco mill want to run vipers with Mach 3
« Reply #1 on: June 27, 2010, 04:36:13 AM »
Hi Jackal,
Here is a link on the CNC zone to my Colchester lathe upgrade using Viper 200s.
http://www.cnczone.com/forums/showthread.php?t=82579&page=3
It explains the tuning a little.
If you know what the PID parameters 'do' in a servo loop then you'll do the tuning quickly.
If not then it will take a bit longer - its easy, if not just a bit of a guestimation exercise,
ATB
Derek
You can "chop it off" but can't "chop it on"
Offline Jackal
  •  171 171
« Reply #2 on: June 27, 2010, 02:29:19 PM »
Thanks Derek,
That lathe sounds pretty sweet.
Jackal
