How is this done then and how is the code created. Must i use a special program or do it manually.
There are all sorts of CAM programs that will produce 4th axis code. Most of them cost a lot of money. Mastercam, VisuallMill, Surfcam, to name a few.
The poor man's way is to take a XYZ toolpath and "WRAP" it around the rotary axis.
This can be done in more ways than you can skin a cat.
One of the easiest ways is to use a program called CNCWrapper,
http://www.cncwrapper.com/I can attest that this cheap little program works extremely well.
However you mentioned that you have a V-carve program. If that was "Vcarve Pro" from Vectric, then this program has a wrapping post processor included.
G2 and G3 commands do not operate on a rotary axis. They are not supposed to. There are ways to cheat and get around this but they are hacks.
Nobody has ever been able to describe to me where it would be an advantage to do so.
Greg
EDIT:
I forgot to mention that DeskProto is a very capable 4th axis CAM program that is offering special pricing to hobby users. 249 Euros
I am very tempted to buy this myself.
![Cheesy :D](https://www.machsupport.com/forum/Smileys/default/cheesy.gif)
