Hello Guest it is July 27, 2024, 08:23:12 AM
Author Topic: Mach 3 and 4th Axis  (Read 59342 times)
Re: Mach 3 and 4th Axis
« Reply #30 on: July 02, 2010, 01:29:31 AM »
Tried the program by Ritch and i keep getting a corrupt file on code i know is working so something wrong there also
Jim
« Reply #31 on: July 02, 2010, 01:37:51 AM »
Greg
Send me your Gcode for that to see if i can get the same result. I know yours works so maybe it can solve my problem, Have you tried mine?
Jim
Offline Greolt
  •  956 956
« Reply #32 on: July 02, 2010, 01:38:25 AM »
Jim
Post the gcode that you are wanting to wrap and I will take a look.
Greg
Offline Greolt
  •  956 956
« Reply #33 on: July 02, 2010, 01:47:56 AM »
OK I had a look at your code.  I can see nothing wrong with it.
However you chose the worst letter to use as a test.  Capital M looks the same backwards.  Even upside down it looks like a W.
Try doing something more meaningful than the letter M.  Like the word "Text" for example.  :)
Greg
« Reply #34 on: July 02, 2010, 02:36:35 AM »
Greg
Thats correct what you say about the M but my point is that the curve is clearly showing to curve along the length of the letter not accross it
Jim
Offline Greolt
  •  956 956
« Reply #35 on: July 02, 2010, 02:40:00 AM »
That just means that you did not arrange it correctly when producing the original code in your CAM program.
Greg
« Reply #36 on: July 02, 2010, 02:56:26 AM »
Greg
I have used the cam as it should be reason i know this is if i show a displayed cut using XYZ then it displayes correct It is only when it is wrapped this occurs.
My thoughts is that there is something not set correct in Mach3 but i dont have a clue what it is.
Unless what you mean by "arrange" is something i am picking up wrongly.
Jim
« Reply #37 on: July 02, 2010, 03:16:47 AM »
Greg
Here are two attachments showing the same word, the word is showing along the length as left to right same as would do in an XYZ cut
but you can see it is still curving the wrong way so why is this where is the mistake in the setup and if you say it is the setup in CAM and you can get it curving the correct way then it must be in Mach the problem lies but i just dont know where?
Jim
« Reply #38 on: July 02, 2010, 09:16:55 AM »
Jim
Jim, please send me the file that is corrupt. I will examine it and see if I can figure out what is wrong. Please send it to my email (rgoldner AT iname DOTcom)  rather than the group.
« Reply #39 on: July 02, 2010, 10:15:14 AM »
Rich
It says that for all the Code files i try but i will send you it within the hour
jim
