Hello Guest it is December 26, 2024, 10:01:27 PM
Author Topic: Problems with write wizzard in mach3  (Read 7584 times)
« on: July 01, 2010, 08:40:54 AM »
I was engraving and after doing several peices I started getting errors,
the first is: scripter compile error.in:
the next is : error on line: 252-type mismatch.
and finally: no shuttle of type selected
I have rebooted the system and still can't get the wizzard to function properly, when you enter text and hit the write button it will not write the code to mach3,
