Hello Guest it is September 20, 2026, 10:54:20 AM
Author Topic: DRO is negative  (Read 13639 times)
Offline CJCNC
  •  24 24
DRO is negative
« on: July 01, 2010, 11:31:19 AM »
Hi everyone,
This is my first question of probably many..LOL
I have a Syil X4 milling machine.  When I home the table to the limiting switches, the DRO in Mach 3 reads Zero, Which is normal, however, when I try to go in the positive direction (to the right), it should be positive numbers, but they are negative instead.  My are being made upside down.  Is there a button in Mach 3 that I can use to switch this around?
Also, how would i go about making the part bigger, (scaling it up 2X for example)?
Finally, to switch from MM to Inches I believe it is G21 and G22, but were in the program do i input these numbers?4
Thanks in advance
Re: DRO is negative
« Reply #1 on: July 01, 2010, 08:56:09 PM »
Your axis is probably running backwards.
The best way to make parts bigger would be in a CAD or CAM program, but you can use the scale DRO's in Mach3, next to the position DRO's.
G20=inches
G21=MM
You can put it in your g-code, or use MDI to change it.
Offline CJCNC
  •  24 24
Re: DRO is negative
« Reply #2 on: July 02, 2010, 06:38:30 AM »
Thanks for the reply,
How do I go about changing the axis direction?
Re: DRO is negative
« Reply #3 on: July 02, 2010, 06:42:06 AM »
Config menu at the top/click homing and limits/then change the red"x" to a green check mark or vice versa under the axis row in the "Reversed" column.
Offline CJCNC
  •  24 24
Re: DRO is negative
« Reply #4 on: July 02, 2010, 07:43:16 AM »
Thank you, I will give it a shot and let you know
Chris
Offline CJCNC
  •  24 24
Re: DRO is negative
« Reply #5 on: July 02, 2010, 07:56:26 AM »
Thanks for your help.  It worked flawlessly.  I never thought it would be so obvious.  I guess all the screens and settings are a little intimidating LOL
Chris
Re: DRO is negative
« Reply #6 on: July 02, 2010, 08:04:08 AM »
Glad it helped, and yes, all these settings can definitely be intimidating. I'm far from a Mach 3 power user so I know exactly what you mean  ;)
