ArtCAM, Deskproto, VisualCAM are not true 4th axis programs.. They always generated gcode for 3-axes...
Meshcam generates code for the 4th axis, the point is it will not generate code so that all 4 axis can be moving at the same time. Or is this not what you are saying?
The main reason for my question is so I can be a bit ahead with my planning. I have a possible requirement to reproduce small complex casting by milling from solid. As it stands at the moment it would seem Meshcam can cope with this but will I need a more sophisticated Cam package in the future, perhaps for speed or smother finished.
I will probably look at bit closer at 'DeskProto Full'
As I am new to Gcode programming what would a simple piece of Gcode look like that would have all 4 axis moving together in a non linear way; for that matter I don’t think I could do it in 3 axis.
Brian
