Hello Guest it is September 18, 2026, 09:45:41 PM
Author Topic: OEM code for Output 2 Toggle  (Read 14903 times)
« on: July 23, 2010, 06:31:33 PM »
Simple enough I just can't find the OEM code for output 2 toggle.  I find output 2 on and off, but not toggle, is there such a thing?  If so what is it?
Thank Evan
Re: OEM code for Output 2 Toggle
« Reply #1 on: July 24, 2010, 04:51:08 AM »
Not that I know of but a simple macro would do the same, you could either write it to a macro or place it in a VB button that you place on the screen.
The VB would look similar to this
If GetOemLED(853) Then
DeActivateSignal(OutPut2)
Else
End If
  •  9,372 9,372
« Reply #2 on: July 24, 2010, 05:48:16 AM »
Evan,
If you wish to toggle Output #2 from within a GCode program :-
The command M50 doesn't seem to get used anymore so by placing the macro Hood has given (minus the Hood line  ;D ) in the macro 'M50.m1s' (delete or rem the stuff that's in there already) then by placing M50 in the GCode this will toggle output #2.
« Reply #3 on: July 24, 2010, 05:57:57 AM »
Oops bloody Netbooks keyboards are too small for me and screens to small to see as well ;D
Now I cant edit it as its been more than 5 mins since I wrote it, that bloody redneck Bretts to blame for that ;D
Just to clear it up, VB should be
Else
End If
« Reply #4 on: July 24, 2010, 06:18:38 AM »
lol! You're just having a heck of a time with that little thing aren't you!  :D
Maybe we need to start a a forum for netbooks ?  ;)
« Reply #5 on: July 24, 2010, 06:47:36 AM »
;D
« Reply #6 on: July 24, 2010, 11:21:25 AM »
Lol I don't want to program it, not looking for VB or Gcode.  What I want is to put a button on my screen to turn on and off my output 2.  I can't find any button codes in the XLS for screen4 to turn on or off or toggle output two.  Just trying to add a button to my screen, that's all.  Anybody know those numbers?  :)
  •  9,372 9,372
« Reply #7 on: July 24, 2010, 11:44:40 AM »
Evan,
I seem to have missed something here - surely Hood has already given you the information you need to do just that.
Add a VB button to your screen then within Mach paste in Hood's VB code and away you go - Output #2  toggles  ON / OFF.
