Hello Guest it is September 24, 2026, 08:32:25 PM
Author Topic: Cutting pockets  (Read 9510 times)
Cutting pockets
« on: August 10, 2010, 09:18:55 AM »
I am trying to use Autocad to make different items and cut out pockets to mount items.  I've been watching a lot of videos on this but what seems to be simple is getting past me.  I am making 2d drawings in autocad and importing them into Mach3 with ok results.  However, when it goes to cut the pockets I created in AC, it is just cutting the outline in Mach3.  What do I need to change to make the tool paths to clear out the pockets instead of just outline them?
Re: Cutting pockets
« Reply #1 on: August 10, 2010, 09:22:31 AM »
And if anyone could tell me how to be able to use the 3d functions so I can create better shapes such as bulges or rounded tops that would be great.  I can create the items in CAD but when I save it as a DXF Mach3 wont import it.
Re: Cutting pockets
« Reply #2 on: August 10, 2010, 10:54:21 AM »
Are you using lazyCAM, or an old version of Mach3? The older importer won't do pockets, and I think LazyCAM needs a license to do them. You may want to look at a CAM program like Vectric's Cut2D.
As for 3D, you'll need a 3D CAM program.
