Hello Guest it is November 19, 2026, 12:15:51 PM
Author Topic: Higher Steps/Unit in Motor tuning- How can i improve the IPM?  (Read 12108 times)
Offline khalid
  •  213 213
    • My Wood carving
« on: August 27, 2010, 10:33:04 AM »
Hi Guys,
I recently purchased G203 V Gecko drives that having 10Microsteps...
My setup for X and Y axes:
Motor= 1.8 degree= 200Steps
Belt Reduction:        3:1
Ball Screw            : 5TPI
Gecko Microstep:       10
Steps/Inch =200 x 3 x 5x 10 =30000 Steps/Inch
I am running my 1GHz processor computer in 35KHz mode.
Now, after automatic tuning  in Mach3  i got 35456.256steps/inch for X and Y axes and 75256.235 steps/inch for my Z-axes.
My speed at X and Y is now limited to 70IPM and for Z axis its more low.Unfortunately, on Gecko the Microstep values is not adjustable... but the drives works great:)
Somebody tell me can i increase the speed without change in Hardware?
If I convert the Steps/inch into Steps/mm can i able to increase the speed?
Re: Higher Steps/Unit in Motor tuning- How can i improve the IPM?
« Reply #1 on: August 27, 2010, 10:46:48 AM »
Change the kernel speed to 45Khz, but you may need a faster PC for that. Or, get a Smoothstepper.
Offline khalid
  •  213 213
    • My Wood carving
« Reply #2 on: August 27, 2010, 11:10:24 AM »
Hi Gerry,
I am thinking of adding 1:1 pully ratio;).. I have read that Backlash compensation is not supported by Smoothstepper .. The next step is up-gradation of the Processsor:)
« Reply #3 on: August 27, 2010, 03:34:28 PM »
Unfortunately
Amir
**Even a clock that does not work is right twice a day**
« Reply #4 on: August 27, 2010, 04:41:22 PM »
Fix the machine then no need to worry about backlash compensation
