Hello
Guest
it is
September 01, 2024, 01:58:25 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
ALL AXIS MOVE WHEN POWER IS APPLIED
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ALL AXIS MOVE WHEN POWER IS APPLIED (Read 4022 times)
inivator
102
on:
September 07, 2010, 07:27:54 PM »
THE MACHINE WAS WORKING, BUT NOW WHEN I APPLY POWER TO THE DRIVES THEY ALL STARTMOVING. I CAN CHANGE DIRECTION OF MOVEMENT WITH THE JOG BUTTONS, BUT CAN'T STOP MOVEMENT......USING A 3 AXIS PROBIIX........
Last Edit: September 07, 2010, 07:37:32 PM by inivator
Logged
Carnoustie, Scotland
Re: ALL AXIS MOVE WHEN POWER IS APPLIED
Reply #1 on:
September 08, 2010, 02:20:29 AM »
Do the DROs in Mach show movement?
Logged
inivator
102
Reply #2 on:
September 08, 2010, 09:19:30 AM »
NO...USING STEPPERS, AND WHERE WOULD THE DRO BE SHOWING..
Logged
manmeran
241
Reply #3 on:
September 08, 2010, 10:13:44 AM »
maybe "GROUND"
check your ground between PC and driver.
Amir
Logged
**Even a clock that does not work is right twice a day**
Reply #4 on:
September 08, 2010, 10:28:25 AM »
The readouts in Mach for each axis. Do they show the axis is moving when your motors move and are not meant to be?
Logged
Print
Pages:
1
Go Up
« previous
next »
