One is for pulse length , from 1 to 5 micro second
This will depend on your electronic connected to the parallel port , some breaker boards need longer pulse than other, if your system is working with this setup, don't change anything, for me, I had to increase pulse duration because I was loosing step.
The step direction is same thing, this is the pulse length in micro second, if you use kind of slow electronic, they will need a longer pulse to activate.
Jeff
And please, type with the Cap off
