Hello Guest it is April 04, 2025, 07:32:16 PM
Author Topic: Impact engraving plugin  (Read 560675 times)
  •  9,284 9,284
Re: Impact engraving plugin
« Reply #110 on: April 01, 2011, 05:34:46 AM »
Are you running the latest version of Mach ?
It is also possible (although not confirmed) that you need to be running a licensed version, not the Demo version as per the .xml you sent me.
« Reply #111 on: April 01, 2011, 05:45:16 AM »
Using the latest version of Mach3 with demo license.
I was considering buying, but if I buy the license and then the problem goes away?
  •  9,284 9,284
« Reply #112 on: April 01, 2011, 05:49:09 AM »
Stand by one, I will remove the license from my version and see just what happens with an unlicensed version.
Back soon.
« Reply #113 on: April 01, 2011, 05:55:58 AM »
hi,
        Thank you very much
Andrea
  •  9,284 9,284
« Reply #114 on: April 01, 2011, 06:10:31 AM »
Removing my license file made no difference so it does not matter if you are using a licensed version or not it should still work OK.
Could you please try with a square image (attached) and see what happens ?
« Reply #115 on: April 01, 2011, 06:21:08 AM »
 Hi, I tried, but the problem is the same.
« Reply #116 on: April 01, 2011, 06:30:21 AM »
Hi,the right image is created using the left lane,the left image is created using the right lane.
  •  9,284 9,284
« Reply #117 on: April 01, 2011, 06:40:53 AM »
Is the total width of the created (double) work the same as the Width (X Axis) you specified in the plugin or is it wider ?
When using the plugin are you clicking on Calculate Parameters after making any changes ?
I am running out of ideas now  :'(
« Reply #118 on: April 01, 2011, 07:09:36 AM »
    if I double x, the result is this.
Push botton calculations after modification.
« Reply #119 on: April 01, 2011, 07:13:31 AM »
   sorry I did not understand your question.
The measures after etching are just those specified in the plugin
