Hello Guest it is October 18, 2026, 03:24:12 PM
Author Topic: Mach3 stops and looses control  (Read 36664 times)
Re: Mach3 stops and looses control
« Reply #20 on: January 17, 2011, 04:03:30 PM »
I am having the same issue, I am able to repeatably have 3 different programs stop on lines 495-497, I can take the programs and remove some lines and start them again and they will run through that line until they again hit lines 495-497. Any ideas?
« Reply #21 on: January 17, 2011, 04:04:57 PM »
You are using the demo version, it is limited to 500 lines.
If you have a licence then it is either in the wrong location or it is corupt.
