Hello Guest it is October 19, 2026, 12:13:22 AM
Author Topic: Mach updates  (Read 9917 times)
Offline Toad
  •  58 58
Mach updates
« on: November 11, 2010, 04:17:11 PM »
Good day all;
If my file gets corrupted in some way, can I download the latest version and not loose the settings and license, or do I have to start all over. The reason I am asking is that I am trying to get a water cooled spindle to run, and I can not, just thought something may be wrong with the program, everything looks like it is set up correctly, but I do not get the 10VDC at the cnc4pc c6 speed control board.
thanks in advance,
Toad
Re: Mach updates
« Reply #1 on: November 11, 2010, 04:41:42 PM »
If you copy and save the xml for the profile you use and also your Mach1Lic.dat then you can place them back into the Mach folder if they get lost during the install. Normally it will not be needed but things can go wrong so always safest to have them backed up. Other things you may want to back up if you have custom brains, macros, screens etc are  the Brains folder, the macro folder, the screenset and the bitmaps folder.
Offline Toad
  •  58 58
Re: Mach updates
« Reply #2 on: November 11, 2010, 05:18:36 PM »
Thanks Hood, I appreciate it
Toad
Re: Mach updates
« Reply #3 on: November 11, 2010, 05:21:40 PM »
No problem :)
