Hi Brian,
The machine I have in the workshop is using rev 3.042.040 and this was the one giving the problems at the start of this thread. The computer in the house, with no machine attached, is running rev 3.043.022 and it is this one that is showing the YZ arcs the wrong way round when using the X axis scale factor of -1. After which version was the fix done?
I do not necessarily believe this is a Mach problem as I have already found a problem within my post processor, the missing K token, and I am not dismissing further errors.
I have now re-compiled my post processor to use IJK mode for all arcs. Are you suggesting the R mode is just as valid? BR549 suggests that the R method is outdated and all arcs should be using IJK methods.
As mirroring is working fine in Y, and it makes no difference to the outcome, there is no panic on the X mirror problem.
Mike
