Hello Guest it is April 24, 2025, 08:49:18 AM
Author Topic: Mach3 2010  (Read 116747 times)
Mach3 2010
« on: November 25, 2010, 10:16:23 AM »
Little sample. Toolbar is still changing daily.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach3 2010
« Reply #1 on: November 27, 2010, 10:12:16 PM »
Great work I am loving it :)
Re: Mach3 2010
« Reply #2 on: November 28, 2010, 07:24:55 AM »
Update.
I'm going to integrate the Big Tex Auto Zero routines. After the initial touch off to a moveable plate, all following tool changes automatically autozero to a fixed plate on the machine. All you need to do is change the tool and press cycle start. I hope to get this working in a few weeks.
http://www.cnczone.com/forums/mach_wizards_macros_addons/100594-mach_3_tool_setter_big-tex_version.html
It'll also have the X-Y auto zero that's in my Aqua screen.
I think I'll also integrate a version of Art's probing wizard. I know it's not the fastest method, but I already have an AutoCAD macro that creates a mesh from it's point cloud.
I need to change the coolant icons to just M7 and M8, since router users don't really use mist and flood. :)
Anyway, the main screen doesn't change, only the tabs.
« Last Edit: November 28, 2010, 07:33:18 AM by ger21 »
Re: Mach3 2010
« Reply #3 on: November 28, 2010, 08:31:57 AM »
I would certainly think Roelli would be quite happy withthis screen set -
Even though it's not my style ( I like what are called by many: Loud and annoying screen sets, lol!), I'm seriously impressed with your work, as it's very clean and "classy" as always, Gerry.
Re: Mach3 2010
« Reply #4 on: November 29, 2010, 03:05:51 PM »
Nice work. I would like to beta test it once you got it done :)
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
Re: Mach3 2010
« Reply #5 on: December 01, 2010, 05:05:10 PM »
Gerry, you are to be congratulated on your screen set. It is the cleanest, clearest, most uncluttered screen I have yet seen for Mach and I for one will definitely be in the queue when you decide to release it. Just brilliant.
Well done,
Mike
Re: Mach3 2010
« Reply #6 on: December 01, 2010, 05:53:26 PM »
Gerry VERY well done,  IF you have ever worked with a new modern controller say a  HAAS it has a very similar feel to it.  AND it is very easy to work with. Easy on the eyes and works WELL with a limited MOUSE approach. Please consider making it more Fbutton freindly and less MOUSE friendly
Keep up the good work. I am impressed with the Function before glitter approach(;-)
Re: Mach3 2010
« Reply #7 on: December 01, 2010, 06:18:36 PM »
Can you be more specific? I'm getting ready to start adding keyboard shortcuts, and any feedback is helpful. Most of the layout is done.
Re: Mach3 2010
« Reply #8 on: December 01, 2010, 06:22:11 PM »
Getting ready to start working on the diagnostics. Most of it is functional right now.
It's going to be $20 when it's done. There will also be a 4 axis version as well.
Re: Mach3 2010
« Reply #9 on: December 01, 2010, 06:24:11 PM »
To be more Fbuttom or Fkey friendly you would apply a Fkey to each button or tab so it can be accessed via the keyboard and NOT require the use of the mouse.  BUT you also need to Lable each button/tab as to the Fkey used.
It wouls also be helpfull IF you could enter data into a DRO without the use of the mouse to hightlight the dro???   Maybe tab thru the options???
(;-)TP
