Hello Guest it is September 10, 2026, 09:44:38 PM
Author Topic: Problem with Reinstall  (Read 10036 times)
« on: December 03, 2010, 10:22:17 PM »
I backed up my Mach 3 CNC_Router files (custom settings) and reinstalled Mach 3 on my computer after a fresh Windows iXP install on my computer, same computer, same operating system as before.
I can't get my custom router files to work properly. If I open up the generic Mach 3 screen I can get my motors to run without any problems. If I load my CNC_Router files from the Mach 3 Loader, I can load up gcode and click on "run" and the screen does its thing like if the CNC was operating but my motors aren't moving, using the arrows to move the motors doesn't work either.
Its the first time I try to reinstall Mach 3 so not sure whats going on exactly. Attached is a screen shot of my router. I'd love to get this working if anyone has any ideas please help, I really don't want to have to go through setting up the software and a table again from scratch.
http://img.photobucket.com/albums/v104/philmailloux/screen.png
Re: Problem with Reinstall
« Reply #1 on: December 03, 2010, 10:59:12 PM »
Check the ports and pins for the motor outputs.
« Reply #2 on: December 03, 2010, 11:16:07 PM »
The ports and pins weren't associated with anything under my custom profile but are adjusted with the regular Mach3 profile. Is there some file I can import in my custom profile to set it all as it was before or do I need to configure everything again from scratch?
« Reply #3 on: December 06, 2010, 05:23:07 AM »
You can copy the standard profile to your desktop, rename it, place it back in the Mach3 folder and start that renamed profile.
