Hello Guest it is April 26, 2025, 12:25:43 AM
Author Topic: Can Mach 3 read these programs??  (Read 4503 times)
Offline LB
  •  9 9
« on: December 08, 2010, 11:00:32 AM »
Can Mach 3 read any of these programs?  AUTO CAD DWG, AUTO CAD DXF, EMF, FMV, GEM, PAT, PCT, PLT, SVG, WMF, WPG.
Can I use Corel Draw with Mach 3??
Re: Can Mach 3 read these programs??
« Reply #1 on: December 08, 2010, 11:33:12 AM »
These are CAD drawing formats Mach does NOT read them directly. They would need to be converted to a GCODE format.  You cna use Corell with mach BUT the final ouput for Mach to be able to use it MUST be a gcode format.
Hope that helps, (;-) TP
Offline LB
  •  9 9
« Reply #2 on: December 08, 2010, 11:39:59 AM »
Thanks for the help.  We are now using Bob Cadv21, and would rather use Corel Draw.  For us, it is much easier to use.
LB
