I currently have a PC with a 2700 AMD 64 running at 2.2gHz, 2GB of ram, Windows XP 32 Pro. Running Mach3 R3.042.029. It's a plasma table using hardware from C&CNC (PlazPak-1A)
While running a program I can have Mach and Sheetcam open simultaniously, and I can switch between both programs, screens in Mach, or draw sheets in Sheetcam while cutting with no issues.
If I open a browser window while cutting Watchdog is usually instantly triggered. If I open the window while not cutting it's hit or miss if Mach will go into reset.
Currently I'm trying to run a webcam so I can watch the table while sitting in my office. I'm running the smallest cam software I can find, maxing out at maybe 25% cpu usage on just that software. At best everything goes fine, at worse the table starts having random movements + torch fires when running the cam. (With Watchdog turned off)
Ideally I'd like to run both the webcam and a remote desktop software... but at this point that may be asking a lot.
Any ideas? I just updated to R3.042.040, but I can't currently do any webcam testing as I'm trying to actually get sheets cut.
Thanks!
