Hello Guest it is September 29, 2026, 07:02:47 AM
Author Topic: Round Corners Motor tuening?  (Read 32488 times)
Re: Round Corners Motor tuening?
« Reply #10 on: November 12, 2006, 06:29:40 PM »
is it running in Demo mode?
Check under Help/About and tell me what version you are running
I am not at the machine now but it was downloaded today. I have a license for 1.84 do I need a new one? I will get some info about the machine up soon.
Gary
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: November 12, 2006, 07:09:37 PM »
Hi, Gary
(do I need a new one?)  NO, Just copy your licence "Mach1Lic" to your C:\Mach3 Folder or where ever your Mach3 is located.
Hope this Helps, Chip
« Reply #12 on: November 12, 2006, 09:56:38 PM »
That is odd... you should have what Hood is showing you :)
Could you look under general Config and see if it is there (It should be)
www.newfangledsolutions.com
www.machsupport.com
« Reply #13 on: November 13, 2006, 07:10:46 AM »
Brian
I have 2.0.009
Gary
« Reply #14 on: November 13, 2006, 07:51:10 AM »
Hi, All
I have it running well except I can not get it to insert the colant code it the gcode. I have the box checked and for some reason LazyCam will skip some cuts I think it gets the correct path but dose insert the M3 to start the laser
Gary
« Reply #15 on: November 13, 2006, 11:25:51 AM »
Post the program and tell me where you think you need to have the M3's
We may have to write a post for you
thanks
Brian
www.machsupport.com
Offline Scott
  •  140 140
« Reply #16 on: November 13, 2006, 11:45:55 AM »
This issue of corner rounding and finding that sweet spot is something that I need to get a grasp on too.  I understand the difference between CV mode and Exact Stop mode and that the acceleration setting for an axis will also come into play.  I'm not real clear on the CV Feedrate and what settings to use there.  The CV angle to me means that a change in the angle/direction of the toolpath less than the setting would cause a exact stop situation.?
What concerns me is having to (after finding the sweet spot for various tasks) remember to set these properly for each job before I run/ruin said job!
As I see it, if I draw up a part and toolpath it, it should be cut that way, not rounded.  Otherwise precision is relative.  Exact Stop mode is not an option for most toolpaths (with the exception of longer sided polygons) as it makes for a jerky/jittery machine.
I don't want to come off sounding critical here, it's just an area I'm struggling with. ???
Scott
« Reply #17 on: November 13, 2006, 11:48:34 AM »
Mail me off list and I will talk you through it and you can post how it works for all the others :)
Send me your number and I will give you a call
thanks
Brian
www.machsupport.com
Offline Scott
  •  140 140
Re: Round Corners Motor tuning?
« Reply #18 on: November 13, 2006, 12:30:31 PM »
Thanks Brian!
Message sent.
Scott
Offline Chip
  •  2,055 2,055
« Reply #19 on: November 13, 2006, 08:53:28 PM »
Hi, Gary and Brian
I'm using Plasma Mode the m3 are fine there, running a Water-jet cutter, m3 on, m5 off.
Just some info., Chip
