Hello Guest it is April 18, 2025, 08:14:54 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 889600 times)
Re: Mach3 2010 Screenset - Now available
« Reply #380 on: August 03, 2015, 07:13:48 AM »
1), If the widescreen versions are too big, then yes, you'll need to use the 2010.set screen.
2) Drag the lower right corner of the window to fit the screen, and you won't see those numbers, which were intended to be hidden. (You can't see them on a 1024x768 monitor)
3) Go to the toolchange tab and enter a value larger than 0 in the Clearance Plane DRO.
Offline phast
  •  13 13
« Reply #381 on: August 03, 2015, 11:48:32 PM »
Gerry,
I adjusted my screen res to 1024x768 minimized the taskbar and used the 2010.set
Everything looks much better!! Also the tool zero worked like a charm.
Thank you
« Reply #382 on: August 08, 2015, 11:23:11 AM »
please sen me sceen like this
thanks
Lam Nguyen
email: tuanlam50oto@gmail.com
« Reply #383 on: August 08, 2015, 11:25:46 AM »
Please send me $20...
« Reply #384 on: August 08, 2015, 11:26:58 AM »
Something like this.
please send me sceen like this
thanks
Lam Nguyen
 ;D ;D ;D ;D ::)
Offline phast
  •  13 13
« Reply #385 on: August 14, 2015, 11:19:14 PM »
Gerry,
Another small problem. I did the initial tool zero the bit touched my fixed plate then moved to the fixed plate on the table
And started cutting but never asked for the tool change. Continued cutting with same bit. I use Vectric Aspire 4.5
the toolpath was generated  with 2 different tools. I can not figure out what to do next.
Can you please help me? I will try attaching the G Code.
Offline phast
  •  13 13
« Reply #386 on: August 14, 2015, 11:21:33 PM »
Miss typo: (touched my fixed plate then moved to the fixed plate on the table)
touched my removable plate then moved to the fixed plate on the table
« Reply #387 on: August 15, 2015, 07:30:57 AM »
In General Config, do you have tool changes set to "Stop Spindle, wait for Cycle Start"?
ANd on the Toolchange Tab, do you have "Ignore M6 Calls" unchecked?
Offline phast
  •  13 13
« Reply #388 on: August 15, 2015, 11:29:18 AM »
In General config it was ignore tool changes. I will change that to stop spindle and wait for cycle start.
On the tool change tab is not checked to ignore m6.
I will try again later Today and let you know.
Thanks for the quick reply!!!
Offline phast
  •  13 13
« Reply #389 on: August 15, 2015, 06:42:12 PM »
Another issue.
Now when the axis moves to the fixed plate location on my table Z travels about one inch down never touches the plate
and zeros out. My fixed plate is about 3 inches away from the bit. When I first setup the initial tool zero worked as it should.
Any ideas as to why is doing that?
Thanks.
