Hello
Guest
it is
July 27, 2024, 12:04:19 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Update and index pulse
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Update and index pulse (Read 7826 times)
Re: Update and index pulse
Reply #10 on:
January 17, 2011, 05:50:44 PM »
Don't see anything wrong in the xml. Not aware of what Hood mentioned about recent versions and the spindle relays.
Triggering test is on page 9 of the wirte up.
Logged
Carnoustie, Scotland
Reply #11 on:
January 17, 2011, 05:53:16 PM »
Rich, I am not sure if that is the case re relays, it could well have been with a test version I had that it was needed.
Logged
N4NV
398
Reply #12 on:
January 17, 2011, 06:03:34 PM »
When I slowly turn the spindle, the index LED in the diagnostics page lights. If I spin the spindle fast, the LED does not light. Turning on and off the spindle from Mach does not have any effect on the index (though I have to control the spindle motor manually). If I run the spindle at 500 rpm the index LED flashes about once per second.
Rich, here is a link that describes the hall effect switches I am using:
http://www.cnczone.com/forums/general_metal_working_machines/31601-yamazen_cnc_knee_mill-5.html
Vince
Logged
N4NV
398
Reply #13 on:
January 17, 2011, 06:07:49 PM »
Ding, Ding Ding, Ding.... Hood gets the prize. I had to enable the spindle relays AND turn on the spindle from MACH and now I have a correct RPM readout. This was changed from my previous version I was running.
Thanks again,
Vince
Logged
Reply #14 on:
January 17, 2011, 06:11:57 PM »
Good to hear.
Out of interest what kind of stuff do you do on a Taig lathe?
Logged
Reply #15 on:
January 17, 2011, 06:15:14 PM »
Great, will add that one to the write up.
Logged
N4NV
398
Reply #16 on:
January 17, 2011, 06:36:26 PM »
Taig is a micro lathe sold here in the USA. It is a similar but nicer and cheaper than a Sherline.
http://www.cnczone.com/forums/vertical_mill_lathe_project_log/70772-cnc_taig_lathe.html
I make stuff that is too big for my CHNC. I am working on an even smaller CNC lathe for watchmaking.
Vince
Logged
N4NV
398
Reply #17 on:
January 18, 2011, 12:17:45 AM »
Oops, I meant too small for my CHNC.
Vince
Logged
Reply #18 on:
January 18, 2011, 02:15:49 AM »
Ha ha, must have been a long day trying to get that index working.
I remember seeing that aquarium lathe a while back, looks like these small lathes are quite usable if you dont get greedy with the cuts
Logged
Print
Pages:
1
2
Go Up
« previous
next »
