Hello
Guest
it is
August 31, 2024, 10:06:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Stepper moving in one dirrection only
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Stepper moving in one dirrection only (Read 7001 times)
Tony Woollacott
67
Re: Stepper moving in one dirrection only
Reply #10 on:
January 22, 2011, 09:38:53 AM »
Hood it is that exact board.
Logged
rrc1962
673
Reply #11 on:
January 22, 2011, 09:50:51 AM »
Did you try swapping the inputs to see if the problem followed?
Logged
Tony Woollacott
67
Reply #12 on:
January 22, 2011, 10:00:28 AM »
Just tried swapping inputs and the problem followed. So do you confirm that its the board?
Logged
Carnoustie, Scotland
Reply #13 on:
January 22, 2011, 10:01:11 AM »
If the ICs are in sockets try pressing them down in case they are not seated properly, failing that hopefully the seller will sort you out.
Logged
Tony Woollacott
67
Reply #14 on:
January 22, 2011, 10:14:26 AM »
Ok, I will try that. Thanks to both of you, you have been a big help.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
