Hello Guest it is September 30, 2026, 12:18:09 AM
Author Topic: Spindel pulleys, Inputs/Outputs  (Read 19277 times)
« on: February 03, 2011, 05:56:52 AM »
I have a machine MACHO 900 with a gearbox with 18 positions.
 I made an automatic change with pneumatic cylinders and  PoKeys card. I have also inverter controlled by PWM. (0 - 150%)
 The problem is, because in MACH I can't set more than 15 Pulleys. Is it possible to add more of them?
 I would also suggest more Inputs and Outputs in Port and pin settings.
 The PoKeys card can controll much more I/O than the two LPTs, but the settings are not available.
 I would suggest also a blank field in "Port and pins" for each Input, Output, Trigger to enter comments (for what is used)
I hope that this would benefit also someone else and that this can be done.
