Where would i go to see what the kernel speed is set to? (I havn't changed it, don't even know how
![Smiley :)](https://www.machsupport.com/forum/Smileys/default/smiley.gif)
, It might be the acceleration, but i changed that, And the problem was happening even when the motor was dismounted (900oz steppers).
Hood,
Yes, when Mach is showing a running speed of , say, 0-100, the motor will, Accelerate from 0-50, then decelerate from 50-100. I don't know the exact numbers, it seems we can get it to going 250 (as the computer reads) before going faster will cause it to decelerate. If youll let me know where to check those settings, or maybe i can load a file that shows all my settings
This machine is electronically identicle to another machine i have. Save the computer. This computer has much less RAM, that my other one.
Secondly, On my machine at home, when i drag the Velocity slider all the way over, it stops at 1184. I have thhis machine (the one with the problems) set at 1000IPM. Same number of Steps per in., mechanicals are identicle drive systems. Steppers are identicle.
