Hello Guest it is April 04, 2025, 03:58:04 PM
Author Topic: Mach 3 toolchange for dummies???  (Read 121787 times)
Re: Mach 3 toolchange for dummies???
« Reply #10 on: February 21, 2011, 12:10:51 PM »
Ok, steps per will be divided by 360 as you are working in degrees, so if its 2000 per motor rev that will be 5.555555555555555555555 for steps per.
On General Config page change to Auto Tool Chnager, should now work from Code.
Not sure about position 1, what exactly does it do?
« Reply #11 on: February 21, 2011, 02:20:37 PM »
Gotcha on the steps per...
I have enabled auto tool changer on the config page. I will try again later today, but I am sure that it was enabled when I was testing yesterday...
Position 1= tool position 1 ie: 0 degrees. for some reason I can get the A axis to move to tool 2-8, but I cant move to 1.
Is there a list of terms for the Vbasic program? I would like to be able to decipher what you have written.
Thanks!
Nate.
« Reply #12 on: February 21, 2011, 02:27:05 PM »
You are using a Turn Screenset? If using a mill screenset it wont work as that sets Mach to mill mode.
Ray Livingston wrote a VB manual http://www.machsupport.com/forum/index.php/topic,12730.msg83052.html#msg83052 there is also info on the wiki which may help.
« Reply #13 on: February 21, 2011, 02:29:17 PM »
Oh I also mentioned it at the beginning but better say again, you will need to home the turret when you start Mach or at the very least always stop in tool 1 so that Mach knows where it is. How you accomplish that will depend on whether you just manually want to rotate or whether you have a home switch and do it via the RefAll button.
« Reply #14 on: February 21, 2011, 02:30:21 PM »
Yes, i'm using the stock default mach3 turn screen set.
I will look into the VB manual..
Thanks.
« Reply #15 on: February 21, 2011, 02:34:33 PM »
If you cant get it working then attach your xml and I will see if I can figure out where the problem lies.
If you add a DRO and a LED to the screenset for A axis and Output 2 respectively then it will let you see whats going on and might help in troubleshooting.
« Reply #16 on: February 21, 2011, 03:54:33 PM »
I read through, and searched the PDF on macro language. (is this language called VB?) you can tell how green I am at this...
I found definitions for all the terms except-
WhileIsMoving
Wend
EndIf
I am guessing that they were so basic as programming commands that it was not deemed nessisary to define them?
« Reply #17 on: February 21, 2011, 04:03:11 PM »
While IsMoving()
Wend
   This is basically just telling the VB to wait until Mach has finished moving or doing whatever.
End If
 This is put at the end of an If staement so that the VB knows its finished with that part of things.
BTW notice the spacing, it needs to be correct or you will get syntax errors, I get them a lot ;D
« Reply #18 on: February 21, 2011, 06:53:18 PM »
Alright "now we're cooking" american slang for- Things are moving right along now...
I found that I had saved the macro you wrote in the wrong mach 3 macro folder...
I can now index from G code to all 8 turret positions.
How can I add the DRO for the A Axis? I have never changed the standard mach3 screen...
Also, will that dro allow me to manually enter ********* number, press enter and have the a axis be then oriented to ********* number?
« Reply #19 on: February 22, 2011, 03:15:33 AM »
Ha ha, we say that too, usually cooking by Gas is the term here :)
You can use one of the screen designers to add a DRO, quite easy to do, just make sure you save your new screen by a name other than standard, that way it wont be overwritten if you update Mach. Just use the View menu in Mach to load the new screen.
No the DRO will just be like an axis DRO giving the position. You can index from MDI or you can make up a VB button on the screen which can index the turret one place at a time.
