Hello Guest it is November 01, 2026, 09:18:25 PM
Poll
Is there a basic tutorial how to config mach3 to run 5 steper motors?
I dont understand
0 (0%)
what this mean, sorry
0 (0%)
Total Members Voted: 0
Author Topic: my 5 step motors acting strangely  (Read 92712 times)
Re: my 5 step motors acting strangely
« Reply #40 on: March 02, 2011, 04:53:49 PM »
And motor tuning the same?
Try swapping the X and Y motors around and see if the problem follows the motor.
« Reply #41 on: March 02, 2011, 04:58:24 PM »
Well the problem didnt follow the motor
« Reply #42 on: March 02, 2011, 04:59:00 PM »
And the motor tuning are the same
« Reply #43 on: March 02, 2011, 05:02:24 PM »
Ok next go into Ports and Pins Motor  setup and change the Step and Dir for X axis to 1 and 17 and then change Y to 16 and 14 and see if when you press the X jog keys if the motor is good, same for other motor when you press Y jog
« Reply #44 on: March 02, 2011, 05:05:21 PM »
Yes now the problem moved from the Y axis to the X axis
« Reply #45 on: March 02, 2011, 05:08:00 PM »
Ok so if you unplug the parallel cable and attach your remote control does the Y axis move smooth?
« Reply #46 on: March 02, 2011, 05:10:30 PM »
Yes than it works moths
« Reply #47 on: March 02, 2011, 05:12:31 PM »
I mean it works smooth with the remoter
« Reply #48 on: March 02, 2011, 05:13:00 PM »
Ok it would seem its a parallel port or Mach problem. I dont see anything wrong in your config so I would guess at a bad port or bad cable, most likely the cable.
« Reply #49 on: March 02, 2011, 05:15:43 PM »
OK, can I try the port with the test software and see if that gives me any information?
