Hi all,
My machine is now functional and calibrated as much as I can with a ruler and magnifying glass - waiting on a DTI arriving.
It runs smoothly but if I move X and Y at once, with a small amount on one axis but large on the other it makes a horrible noise and vibrates.
For eg, from 0,0 I can do G1 X50 F500 and it works fine as does G1 Y50 F500 but, if I have say G1 X50 Y1 F100 it hates it and sounds a bit like when you have the step timing wrong on a stepper or try to use too low a voltage for a set speed - not exactly the same but similar.
Hard to explain, I know but Im sure someone must have come accross this problem too. If anyone can offer any assistance? All 3 axis work fine and can move together at all speeds except when one has a small distance to go and one has a lot more to go.
