Hello Guest it is September 15, 2026, 07:48:15 PM
Author Topic: Radius tool compensation  (Read 19389 times)
« on: May 06, 2011, 11:07:47 AM »
Hi guys,
I was wondering if there is the following options in Mach3:
Let's suppose I make a program using my CAD/CAM and use a tool radius 1.2mm.
In case that the radius of the tool changes from 1.2mm to 1.1mm, is there an option in MAch3 that allows me to change it instead of re-do the program again with different radius?
Thanks nad regards
Re: Radius tool compensation
« Reply #1 on: May 06, 2011, 12:46:39 PM »
Yup,
Search G40 G41 and G42
ATb
Derek
You can "chop it off" but can't "chop it on"
« Reply #2 on: May 06, 2011, 09:22:18 PM »
IF your cam is doing the offsetting before the posting of the code then NO.
If your cam is using Tool Comp then YES.
Offline kak
  •  81 81
« Reply #3 on: May 06, 2011, 10:53:05 PM »
There is something called "Diam. Wear" and "Hight Wear" in Config/tooltable, but Im a newbee -I dont know how to use it.
« Reply #4 on: May 06, 2011, 11:20:29 PM »
They don't do anything. They will in V4, though.
« Reply #5 on: May 07, 2011, 11:59:33 AM »
So nothing works yet??
the g40,41... are used for the matter I'm interested into or something else?
thanks
« Reply #6 on: May 07, 2011, 01:06:45 PM »
G41/G42 will use the tool diameter in the tooltable, but they won't take into account the diameter wear values.
« Reply #7 on: May 10, 2011, 09:00:25 AM »
Thanks ger, really appreciated.
So with those G you choose a tool in the tool table but my question is: what's the point if they don't take in account the diameter of the tool??
What's its use??
Thanks again man.
« Reply #8 on: May 10, 2011, 10:05:14 AM »
They do use the diameter, but not the values in the wear column.
« Reply #9 on: May 10, 2011, 10:25:42 AM »
ahhhhh I can't understand what you mean....
To simplify all, would the G42 do what I need?? (change the radius of the tool without do the program again?)
