Hello
Guest
it is
July 27, 2024, 08:47:16 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Feedhold
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feedhold (Read 4304 times)
machfab
17
Feedhold
on:
May 19, 2011, 06:06:04 PM »
When I feedhold on my waterjet gantry, the Gecko's (g320's) will fault out. Usually one or sometimes both. Are the ramp settings on the motors set too aggressively, or is it something else? Thanks in advance
Logged
Carnoustie, Scotland
Re: Feedhold
Reply #1 on:
May 19, 2011, 06:42:14 PM »
Cant see how feedhold can do that as it is a controlled stop and if a normal rapid doesnt trip the drives when it stops moving then no way a feedhold should, I take it you can do a rapid move without issues?
Logged
machfab
17
Re: Feedhold
Reply #2 on:
May 19, 2011, 06:58:51 PM »
rapid is no problem only feedhold
Logged
Re: Feedhold
Reply #3 on:
May 19, 2011, 07:16:40 PM »
Does it fault right away?
Does Mach go into reset or is it just the drives that trip?
Any message in the ticker window in Mach?
Are you using the standard screenset?
Logged
machfab
17
Re: Feedhold
Reply #4 on:
May 19, 2011, 08:00:36 PM »
Actually, after looking at it closer, it faults on rapid moves if I hit "stop". I am using the Machblue screenset. Just the drive or drives trip. Mach does not fault and has no message.
Logged
Re: Feedhold
Reply #5 on:
May 20, 2011, 02:20:54 AM »
Stop will almost always fault if you use it when in motion as it stops pulses instantly and your momentum is highly likely to carry your axis beyond the following error limit of your drives and thus fault them. Feedhold should not do that though as it is a controled stop where Mach will decelerate at the rate set in motor tuning.
If frrghold is causing a problem then there is something wrong, try the standard screenset as it could be a hotkey or even an OEM code miss set in the screenset you are using.
Logged
machfab
17
Re: Feedhold
Reply #6 on:
May 20, 2011, 06:12:11 AM »
I will try that. Thanks for your help
Logged
TOTALLYRC
861
Re: Feedhold
Reply #7 on:
May 20, 2011, 06:49:22 AM »
The Gecko site has a diagram to wire the err terminal into Mach so it sees the drive fault and goes into e-stop
Logged
Print
Pages:
1
Go Up
« previous
next »
