DOes it do this on EVERY small sharp corner? IF so then LOOK to the servo tuning, too much overrun will do it every time. The servo will overun the position and then back up to correct.
Just a thought, (;-) TP
BR549, please explain overrun and how one would go about detecting whether it is in fact what's busy happening?
Just to clarify some things that Marius1975 missed in mentioning:
The machine uses ball screws on all axis, driven by servo motors.
All axis has been calibrated and are 100%
We have cut the exact same program (gcode) using the exact same cutter on a HAAS machine and it came out perfectly.
The problem only occurs when doing "corner sharpening" and affects all areas that requires corner sharpening.
