Hello Guest it is October 02, 2026, 04:26:15 AM
Author Topic: My drill wont drill!  (Read 16916 times)
Offline sn96
  •  60 60
« on: May 29, 2011, 04:19:44 PM »
Hey guys, I'm having a problem with drilling operations. The drill will go to the proper x,y locations but it wont plunge, it just stays in the clearance plane and goes from location to location. I have included the g-code its a simple small bracket that has four holes set to drill .1" deep the material is .09" thick.
The code is generated from visual mill 6.0 and my machine is a Sherline 5400 inch. It will mill without any problems, for some reason the drill operations don’t want to plunge.
N1 G00 G49 G40.1 G17 G80 G50 G90
N2 G20
N3 (Standard Drill )
N4 M6 T2
N5 M03 S1500
N6 G00 G43 H1 Z1
N7 G01 X0.3954 Y0.5986 Z0.1000 F3000.0
N8 G00
N9 G81 X0.3954 Y0.5986 Z-0.19 R0.01 L0.0
N10G80
N11 G00 Z0.1000
N12 G81 X0.7234 Y0.9266 Z-0.19 R0.01 L0.0
N13G80
N14 G00 Z0.1000
N15 G81 X0.7234 Y0.2706 Z-0.19 R0.01 L0.0
N16G80
N17 G00 Z0.1000
N18 G81 X1.0514 Y0.5986 Z-0.19 R0.01 L0.0
N19G80
N20 G00 Z0.1000
N21 M5 M9
N22 M30
Thanks for any help at all.
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Re: My drill wont drill!
« Reply #1 on: May 29, 2011, 04:23:49 PM »
Get rid of the L0.0
The manual said L=0 is not allowed.
Try it like this:
N2 G20
N4 M6 T2
N5 M03 S1500
N6 G00 G43 H1 Z1
N8 G00
N10G80
N11 G00 Z0.1000
N13G80
N14 G00 Z0.1000
N16G80
N17 G00 Z0.1000
N19G80
N20 G00 Z0.1000
N21 M5 M9
N22 M30
Offline sn96
  •  60 60
« Reply #2 on: May 29, 2011, 05:10:10 PM »
BINGO! that did the trick. My drill now drills :)
Thanks for your help! this made my day! Been fighting this issue all morning.
Mike
windows 10
i7 laptop
Offline sn96
  •  60 60
« Reply #3 on: June 02, 2011, 03:51:03 PM »
Ok I have a new question regarding drill operations. If I need to drill a deep hole, having the drill cycle to break the chip would be useful. What format does Mach3 Recognize so that it will retract a little to break chips? I want to be able to edit the visual mill post processor (Mach3-Sherline) so that the "break chip" option will post the proper G-code that Mach3 will recognize.
Any help would be greatly appreciated.
Mike
windows 10
i7 laptop
« Reply #4 on: June 02, 2011, 04:23:20 PM »
will visual mill send out a "peck" operation?
« Reply #5 on: June 02, 2011, 04:34:28 PM »
G73 Peck drilling in increments to break chips
G81 Straight drilling
G83 Deep Hole Peck drilling, Drill retracts out of the hole each peck to clear chips
IT is ALL in the manual (;-) , TP
Offline sn96
  •  60 60
« Reply #6 on: June 02, 2011, 05:10:53 PM »
Yes visual mill will create peck operations but the format is a  little different. I will need to modify the post processor to output the correct G-code.
Mike
windows 10
i7 laptop
Offline sn96
  •  60 60
« Reply #7 on: June 02, 2011, 08:28:31 PM »
Here is a photo of a bracket I designed using ViaCad2d/3d , posted using Visual Mill 6.0, and then cut on a sherline 5400 milling machine with the CNC upgrade. The holes were my problem at first until I removed L command.
I thought I would share what I was working on:
« Last Edit: June 02, 2011, 08:30:41 PM by sn96 »
Mike
windows 10
i7 laptop
« Reply #8 on: June 02, 2011, 08:48:02 PM »
Looks Good from here
« Reply #9 on: June 03, 2011, 04:38:39 AM »
There are peck drilling macro's in the Tool Box, here is the link.
http://www.machsupport.com/forum/index.php/topic,15205.msg101682.html#msg101682
