Hello Guest it is October 02, 2026, 07:40:27 AM
Author Topic: stopping and restarting a job smoothly  (Read 9565 times)
« on: June 03, 2011, 02:18:42 PM »
Hi all,
Just a simple question I am running an extremely long job (very detailed lithograph)but the bad news is I am running inside a room in my Apt. so although the noise is Ok during the day my neighbors probably wouldn't care to hear it all night along so I need to stop the job mid way and then restart this could be at any point during the run so what is the best way to accomplish this.
 I tried the stop and then run from this line but I ended up with a noticble line where the job was stopped any other better proedures out there
Jeff
Re: stopping and restarting a job smoothly
« Reply #1 on: June 03, 2011, 04:00:17 PM »
The big problem as you have found IS that when your machine is shut down the axis's may DRIFT from the exact position as there is NOTHING holding them in position.AND when you restat the Motoros tend to jump to the next full step. either forward of backward.
The only sure way is to develope a plan to be able to reset the machine to an exact know position in all axis's before to attemp to restart.
Here I use block of alum that has a hole machined into it an a milled top surface. It is bolted to the table way out of the way.  Then when I start a project AND I have the 0,0,0 all set, I probe for the center of the hole and check for the top of the block and write down these figures OR put them in NOTES in the program itself.
IF I need to restart I just got back and reprobe the hole and set the bit to the top of the block and type in the new numbers to the dros. This ensure that I am on the exact coords base as the part I am working on.
You can do the same thing by milling the Block square on the X and Y axis while it is bolted in place. Then do a touch off on the x axis and reset Xdro then touchoff the Y axis and reset the Y axis. then touch off on Z.
As long as you did not move the block it will always return the same position.
Hope that helps, (;-)TP
« Last Edit: June 03, 2011, 04:03:19 PM by BR549 »
« Reply #2 on: June 03, 2011, 04:58:59 PM »
Fitting accurate home switches are a good way, you can then rehome and do a run from here.
