hello i have a spindle speed problem. i set up a bridgeport with a automation direct vfd and changed out the cones for timing pulley and cogged belt this worked fine then mach said compile error in spindle speed.m1s so i replaced the file and it worked. next i read about a mach problem with spindle speed so i set pulley 1 to 510 - 4200 rpm and pulley 2 to 60 - 500 rpm ratio 3 i didnt check reverse in pulley 2 this worked so i thought i had the problem worked arround checked numerous times ran ok. now mach has shreaded the file again. so did some more reading found the file setup in spindle speed was supposed to be set up wrong so redid file to put both command on seperate lines worked worse then before. so can sombody tell me exactly what is wrong with spindle speed and reverse, the best repair option thank you mark
