Hello Guest it is December 30, 2024, 11:55:24 AM
Author Topic: X axis profiling positioning out??? Please help.  (Read 3613 times)
« on: June 24, 2011, 03:27:11 AM »
Hello
I've just bought a proxxon mf-70 cnc mill and I'm have problem with profiling positioning on the x axis.
The problem is the the pockets with arcs in the body of the part are .2mm's out to the outside profile of the body?
Y axis is fine (symmetrical) but again out .2mm's in the x axis (where it should be symmetrical)
I calibrated the axis, there's no back lash in x and y.
Also if I make the pockets square without any arcs in there it comes out fine??
So I'm assuming it's a problem arcs??
The pocket sizes and distantance from each other are fine again 0.2mm's out in x+ ???
The part is a test piece 20x20 square with pockets in each of it's corners leaving a wall thinkness of 1mm.
Hope some one can help.
Daral.j
Re: X axis profiling positioning out??? Please help.
« Reply #1 on: June 24, 2011, 06:42:59 AM »
Can you attach a pic showing the problem
« Reply #2 on: June 24, 2011, 07:56:53 AM »
Hello and thank you for replying.
I have just this miniute figured out what it is.
In my CADCAM i had programmed it to do the outer body with tool comp.
The post processor for it had not put the g-code in to allow compensation!
Feel a bit silly now! Ha ha!
Again thank you for reply to help.
Much appreciated.
Daral.j
« Reply #3 on: June 24, 2011, 09:45:50 AM »
Good that you found the problem :)
