Hi Guys
Thanks again.
This is becoming a comedy saga where everyting that should be simple just does not go your way. Really fed up now but some day I am sure I will look back and laugh.
I un-installed the card in device manager and just to make sure I removed the card and re-booted the computer (silly me).No LTP3 port, good. I turned off the computer fitted the card, turned on the computer expecting to install using the CD and hopefully get an EPP option (there are no jump lead options on the card), but no, it installed it's self, just seemed to pick up the un-installed drive if that makes sense, so no further forward.
In desperation I went out and bought another parallel port card. It says it supports EPP. Did the necessary, turned on the computer, no found new hardware message, it just installed LTP3. As it turns out, although a different card it has the same moss chip and just seems to have picked up and re-installed the installed drive. (is that possible?) Can't see how to get it to install from the CD even after un-installing it in device manager.
How do you get these cards to operate EPP?
Nothing in Bios, nothing in device manager etc to change config.
How do you un-install and get it to re-install from the CD (assuming there is an option on the CD for EPP)?
Cheers Guys for your continued support. I just hope eventually I get this going.
I have had enough for today.
Nigel
