Hi Hood
Ok, I have tested both the db25 plug that fits to the drive and yes, now that you mention it, I can see the pin no's.
Don't know if it makes a difference but for this test I set mach3 to port 378, kept mach 3 running with the reset button pressed to clear e stop message.
First I tested the db25 that plugs into the drive, then disconnected the ribbon cable (computer still running), then tested the pins on the mother board.
Mixed results
On the db25 results are.
Pins 1 to 16 have 5v
Pins 17 to 25 ov
On the mother board
All Odd no's 5v + pins 2,4 & 6 5v
Remaining even no pins 8 to24 0v
Nigel
