Hello Guest it is January 02, 2025, 03:49:59 PM
Author Topic: Need help with collet closer macro  (Read 3406 times)
« on: June 28, 2011, 03:11:33 PM »
Hello all,
I'm getting the air-operated collet closer working on my lathe. I have written the following macro, and it is working:
M101 (open collet) DeActivateSignal(Output5)
                           ActivateSignal(Output4)
M102 (close collet) DeActivateSignal(Output4)
I would like to add something to the open macro to prevent the collet opening when M3/M4 are active. Just as a safety precaution I guess.
How do I do this?
Kevin
Re: Need help with collet closer macro
« Reply #1 on: June 28, 2011, 04:16:06 PM »
Something like this would maybe suit.
If GetOEMLED(11) Then
End
Else
DeActivateSignal(OutPut5)
ActivateSignal(OutPut4)
End If
That should look at the spindle LED and if its on will end the macro, if not it will do your outputs.
« Reply #2 on: June 29, 2011, 02:00:46 PM »
Thanks, Hood.
Worked perfectly.
Kevin
« Reply #3 on: June 29, 2011, 02:02:42 PM »
No problem :)
