Hello
Guest
it is
September 01, 2024, 02:30:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
how to setup motor parameter in Mach3 when I use service motor
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: how to setup motor parameter in Mach3 when I use service motor (Read 3186 times)
wyb_506
22
on:
July 02, 2011, 04:16:23 AM »
as the topic :
thank you!
Logged
Carnoustie, Scotland
Re: how to setup motor parameter in Mach3 when I use service motor
Reply #1 on:
July 02, 2011, 04:46:27 AM »
If you are meaning servo motor then it is the encoder count you use for the steps per unit calculation.
Would need a lot more info to say more.
Logged
wyb_506
22
Reply #2 on:
July 03, 2011, 08:27:52 PM »
ok thank you
I want to know how to setup servo motor ,step by step, because I am a new user for mach3
Logged
Reply #3 on:
July 07, 2011, 07:16:14 AM »
You will have to give a lot more info for any help to be given.
Do your drives accept Step/Dir input?
What line encoder do you have?
What RPM is the motor rated at?
Any gearing between motor and screw?
Any electronic gearing in your drives?
What pitch of ballscrew?
Logged
Print
Pages:
1
Go Up
« previous
next »
