Yeap I have a pair of these as well, You can set your encouder counts to where you want it to home back TOO!!! and it repeats to that count every time!!! Your accuracy of home is only limited by your Mechanical back lash at that point. Further they are TRUE opto isolated, you can run 2 supplies, one for TTL level, and one for 12, 24 or what ever volts on your field side. The Encouder inputs allow Differential Encouders, that will translate to the Single ended on the other side of the board if you use stuff like Geckos. True HIGH speed optos 10 MHZ!!!!!!
Since I use PLC's, I also use his 24 bit High Speed Opto Card, you can run upto 4 different supplies with this One supply per 12 inputs or out puts!! This allows me to convert TTL signals from Mach to the 24 volt that ADC PLC's like, and back to mach.
Check him out, His boards may be higher than others, but The boards are HEAVY duty and well made, the components used alone are almost worth the price of the board. You really DO get what your pay for, my homing routine on my Mill is now repeatable to within 2/10ths.
Scott
