Hello Guest it is December 26, 2024, 11:39:20 AM
Author Topic: G31 Probe problem  (Read 67384 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: G31 Probe problem
« Reply #70 on: August 04, 2011, 12:45:12 PM »
but just for the hell of it can you post your macro please?
Ian
« Reply #71 on: August 04, 2011, 03:50:58 PM »
Everything is working great with 28.1 now. The plate height check is very fast.
Here is my macro
PierceHeight = GetUserDRO(1000)
CutHeight = GetUserDRO(1001)
PierceTime = GetUserDRO(1002)
CurrentZ = getDRO(2)
While IsMoving()
Wend
If GetOEMLed(825) = 0 Then
Code "G28.1 Z" & CurrentZ
While IsMoving()
Wend
Code "G92 Z0.0"
While IsMoving()
Wend
Code "G0 Z" & PierceHeight
While IsMoving()
Wend
DoSpinCW()
While Not isActive(Input1)
Wend
Code "G4 P" &PierceTime 'Pierce Delay
While IsMoving()
Wend
Code "G0 Z" & GetUserDRO(1001)
While IsMoving()
Wend
Else
Code "(Torch is On Surface Hit STOP and Fix)"
End If
« Reply #72 on: August 04, 2011, 04:09:01 PM »
Glad you got it shooting sparks like you want it.
« Reply #73 on: August 04, 2011, 06:19:47 PM »
It shoots sparks, but not quite like I want since I get to start a new battle with the high freq plasma noise interfearance ... yay
« Reply #74 on: August 04, 2011, 06:28:51 PM »
Sheilding and grounding are your best buds
« Reply #75 on: August 05, 2011, 08:34:50 AM »
So G28.1 fixes it.  Can we conclude that there is a problem with G31?  for whatever reason...maybe a config setting...on my machines, Z axis G31 accel follows the X or Y axis.  If memory serves, it follows the X.   I was hoping to see a G31 fix come out of this thread.
« Reply #76 on: August 05, 2011, 10:34:23 AM »
YEP, I will agree there is a problem with G31 as you stated(;-). You may want to run this by Andrew for further testing before they will consider a fix.
The main reason I would never had seen it is I run all the axis's at the same parameters for accel/velocity.
Good Job, (;-) TP
« Reply #77 on: August 05, 2011, 10:47:01 AM »
So do I.  Every now and then I play around with the accel settings.  That's when I notice it.  Other than some random testing, I run all axes at 30.  Stirling tested this and said it was fine on his machine...Z axis G31 followed the Z axis accel settings.  That's why I was wondering is it was a config setting.
« Reply #78 on: August 05, 2011, 11:18:31 AM »
 I am not sure I know of any config setting that would effect it that way. I do not have a machine setup here at the house to test probing with Mach3 and Vista64 do not get along (;-) and will not simulate correctly. SO I cannot say one way or the other. BUT looking at the test vid would indicate there IS a problem. You can see and hear the difference. I used a sound analyser to see the ramp and decay of the sound the motors made.
Many years of loud noise leaves you half deaf in many freq ranges so I have to SEE the sound sometimes.
(;-)TP
Offline stirling
  •  2,188 2,188
  • UK
« Reply #79 on: August 05, 2011, 11:26:11 AM »
Certainly a strange one. I too normally run all three at the same settings but played with them to test this out. Like I say - all seemed well. Just a shot to nothing - you guys haven't got/had anything going on with swapAxis() by any chance? (clutching at straws here).
Ian
