Hello Guest it is December 21, 2024, 11:45:33 AM
Author Topic: importing coordinate list  (Read 19337 times)
Re: importing coordinate list
« Reply #40 on: September 25, 2011, 12:42:27 AM »
Got Jcode now but still working on Copycat.  Isn't this mach amazing.  Probing, video - all
kinds of stuff to make a day fun...
« Reply #41 on: September 25, 2011, 12:53:55 AM »
You need to unzip the copycat and make sure it goes into the right directory. normally c:\mach3\addons\copycat  Then start go to mach3 and select "Select wizards" then select copycat.
There are 2 screens one manual copy and the other Probe copy.
NOW IF the copingkatting does not suit you there MAY be another way Using a new page program that does some magic with the encoder. But that is a last resort,(lot of work)
« Last Edit: September 25, 2011, 12:57:08 AM by BR549 »
« Reply #42 on: September 25, 2011, 01:05:18 AM »
Ok, got Copycat, I had an old Mach demo version on this computer, Copycat
comes with default stuff.  Just had to download current Mach version.
Docs show a video versus probe and that is exciting! Cant get to bed, too much
to think about
« Last Edit: September 25, 2011, 01:18:49 AM by thespindoctor »
« Reply #43 on: September 25, 2011, 12:02:30 PM »
OH boy another one HOOKED on Machcrack, the lastest designer drug.
LOLOLOLOLOL go for it, (;-) TP
« Reply #44 on: September 25, 2011, 12:35:53 PM »
  I've been hooked for years with 4 machines now running Mach!  The 4th one is
a retrofit for a Mori Seiki SL1 lathe that I am just starting.  That will be a real upgrade in
difficulty and require learning to program a PLC.  So if I sound lost now, just wait until
I start that project...
