Hello
Guest
it is
September 01, 2024, 01:47:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
malfunction in toolpath
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: malfunction in toolpath (Read 2704 times)
grandpa
1
on:
October 05, 2011, 11:20:08 AM »
I have a problem when running a 3d tool path, it goes just fine then for no reason it will move the starting point. And then the project is just a scrap of lumber, has anyone else had this problem?
Logged
Carnoustie, Scotland
Re: malfunction in toolpath
Reply #1 on:
October 05, 2011, 11:34:13 AM »
Can you attach our xml and also the code you are having issues with and say roughly the line number in the code where the problem appears.
Logged
ger21
6,295
Reply #2 on:
October 05, 2011, 11:37:48 AM »
Sounds like your machine is losing steps and losing position. Try lowering the acceleration by 50%.
Logged
Print
Pages:
1
Go Up
« previous
next »
