Hello Guest it is December 21, 2024, 12:13:17 PM
Author Topic: were tp look?  (Read 2913 times)
were tp look?
« on: October 21, 2011, 12:11:48 AM »
Hey guys,
  I'm new to the forum.I had my router up and running,jogging playing around with It when all a sudden I lost my X Y movement.The Z still works.I ran the X Y leads to the z one at a time and the motors work.To day I changed out the board with a new one.Still the same problem only Z runs.When I turn it on all the motors set the brakes,but will not jog! Just the Z jogs.Any Ideas?
Thanks Randy
  •  9,279 9,279
Re: were tp look?
« Reply #1 on: October 21, 2011, 03:16:48 AM »
Hi Randy,
Some more details on your setup would be useful.
What type of breakout board and stepper controllers are you using ?
Have you checked that the step and direction pin settings within Mach are correct for the X and Y axis ?
Also - check your keyboard regional settings as the X and Y jog keys (arrow keys) may not be operating correctly.
« Last Edit: October 21, 2011, 03:19:30 AM by Tweakie.CNC »
