Hello Guest it is September 19, 2026, 10:35:16 AM
Author Topic: random ramping to a stop .  (Read 11257 times)
« on: October 25, 2011, 11:04:01 AM »
i have a problem with mach randomly ramping to a stop in the middle of a gcode file. i cut panels 144x30 with holes and slots cut out. no problems with the holes but when the outside of the panel is cutting, mach will ramp to a stop randomly 4 - 5 times. i have changed the look ahead numbers but did not help. this is on a plasma cutter.cut speed 200 ipm. i tried turning off preview . did not help.
running out of memory? no other apps running besides mach and xp.
Re: random ramping to a stop .
« Reply #1 on: October 25, 2011, 11:14:12 AM »
When you say Ramping to a stop I am thinking SoftLimits, is there a message saying that you have encountered the softlimits?
« Reply #2 on: October 25, 2011, 11:19:52 AM »
no nothing like that. just slows to a stop and then starts back up.
« Reply #3 on: October 25, 2011, 05:44:35 PM »
Possibly a CV setting?
« Reply #4 on: October 25, 2011, 07:19:17 PM »
Is it running the outside in exact stop mode? Is it starting, stoping, re-starting while executing a single line of code?
« Reply #5 on: October 26, 2011, 11:13:48 AM »
its in cv mode.  the gcode for the outside is
g0z.7
g0x0y30.07
m3
g01x144.07 f200
y30 x0
y0
m5
g0z.7
m30
it will come to a stop on panels 72 in length and over. i am baffled. did not do this ever until 3 months ago. it is a foxconn atom board with onboard video. 1 g ram.
