Hello Guest it is May 23, 2025, 02:58:13 AM
Author Topic: NFS Turn Wizard  (Read 507548 times)
NFS Turn Wizard
« Reply #220 on: December 19, 2015, 03:52:25 AM »
Thanks Ron.  So could you perhaps guide me to where one can find the licensing page to buy a license for nfs turn please?
Sent from my iPad using Tapatalk
Re: NFS Turn Wizard
« Reply #221 on: December 21, 2015, 05:13:48 AM »
Anyone, please?
  •  9,285 9,285
Re: NFS Turn Wizard
« Reply #222 on: December 21, 2015, 05:35:59 AM »
Anyone, please?
The Mach3 Addons license enables several different components: CopyCat, Multi Pass, PowerFeed XY, the Mach3 Addons for Mill, and the NFSTurn wizards, which are a solution for using Mach3’s wizard capability to simplify the creation of G-Code files.   http://www.machsupport.com/software/mach3-addons-for-mill/
You can use the contact form to confirm that you will be purchasing the correct license for the product you require.   http://www.machsupport.com/contact-us/
Re: NFS Turn Wizard
« Reply #223 on: December 21, 2015, 06:27:02 AM »
Many thanks Tweakie.  Just to be sure, it looks like the add-ons come with R3.043.066 as a package, then they get unlocked by the license?
Thanks, John.
Re: NFS Turn Wizard
« Reply #224 on: December 21, 2015, 08:37:28 AM »
The license will unlock any version of Mach3. When you buy the license you get only the license key, you must also download and install Mach3.
Re: NFS Turn Wizard
« Reply #225 on: March 13, 2016, 03:41:20 PM »
Hi Ron,  Just installed 009 on the latest version of Mach3 and when I open it in wizards I just get a blank screen.  I do have both a Mach3 license and NFS add-on license for mill.  I'm sure I must of did something wrong but no idea    Unzipped it and put the whole folder in Mach3turn add ons folder.  It comes up in wizards like I said but no go.
Thank you,
Jack
Re: NFS Turn Wizard
« Reply #226 on: March 13, 2016, 09:03:06 PM »
That means it cannot find the screen set. It should be in the NfsTurn folder under turnaddons called NfsTurn.set.
Re: NFS Turn Wizard
« Reply #227 on: March 13, 2016, 09:54:32 PM »
OK, that makes sense. I know it is there so I'll move it to screen sets.
Re: NFS Turn Wizard
« Reply #228 on: March 13, 2016, 11:04:08 PM »
Ron new user just received my machine and down loaded NFS Turn
I have an issue with the spindle direction in both wizards, the rotation stays CW. In turn, I have to edit the program with M4. In NFS I built the tool and checked front post and CCW. When I post it it remains M3. In both programs after editing, if i stop it and restart it the program defaults to M3. Any ideas on what switch I need to change.
Re: NFS Turn Wizard
« Reply #229 on: March 13, 2016, 11:39:19 PM »
Ron,  I checked the folder and it's in there.  nfsturn.set.   I originally put the whole folder in mach3 turn addons like it said in this forum page one.  Any thoughts?
